VSC Light On
Just to be sure... Battery and alt are fine? Got a code reader? See if you can pull any codes. All of the lights usually light up when "Check VSC" comes up.
Otherwise, let the car sit for a bit and then go out and try to crank it. If it starts up and dies after 2 secs, and won't start up after, fuel pressure sensor.
