MPG issue
Hi guys new to the forums, i bought a used 2010 Lexus IS250 awd in Canada, now i have been driving it for a while and the MPG is funny. Can someone help me, when I filled up for the second time i used up 75% of the tank and got 180 miles on 12.46 gallons of gas. Ive read many other posts on this website and have seen that people get MUCH better mileage. Im basically missing about a 100 miles off a tank. Can someone tell me where i can start to fix this issue.
I live in a town outside of Toronto, its not all break and stop its about 80% city and 20% highway.
Thank you!
Thank you!
Super Moderator
According to my calculation, that's only 14.45 MPG, which I agree is terrible. Did you do a lot of short trips? The combination of short trips (where the car barely has a chance to warm up) and cold weather really takes its toll on fuel economy.
Shaq32 (02-13-17)
Thanks for your reply and yes many short trips and weather is cold here lol, so for a better MPG, I should drive further ? and will see it improve in the summer months ? furthermore, if i were to replace spark plugs, air filter and engine oil would that help also? because i haven't done so since i got the car about a week ago.
Shaq32 (02-13-17)
Shaq32 (02-13-17)
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Very strange to see this, and on a 250 nonetheless. I usually tend to get ~20 - 24 combined (80% city / 20% highway) and I don't usually rev above 2000 RPM. Unless you're always flooring it (which is understandable, 250s have no power) there might be something with your engine (I'm no expert whatsoever, this is just a hunch). Are you certain you don't have a fuel leak?
Shaq32 (02-15-17)
Wow that is indeed terrible. I get at least 25 mpg, living in Ottawa,ON with my average trip less than 10-15minutes and I'm not the slowest driver either. Are you using manual mode? I can only imagine fuel economy that bad if you were just chilling above 4k/5k rpm all day.
Shaq32 (02-15-17)
https://www.clublexus.com/forums/is-...nsor-leak.html
I've also seen leaks from bolts near the suspension where you install the sway bars. Something else to possibly look at. Keep in mind I'm no expert. Have you gotten your car inspected? Any error codes?
Shaq32 (02-16-17)
I'm not certain as to how to tell, but I saw this post on a recall:
Also, make sure your tire pressures are set to the factory specified PSI's shown on the driver door - should be 35 front and 37 rear.
srinuchall
HS 250h Model (2010-2012)
09-30-16 08:19 PM
