Stock exhaust - driver side exhaust tip hanging much lower than passenger side
Old 03-04-17, 08:28 AM
Soledad
Soledad's Avatar
Default Stock exhaust - driver side exhaust tip hanging much lower than passenger side
All, I've been working a lot and it's been raining a lot and so I haven't had time to check it out yet. But, the other day, pulling into my driveway I noticed the driver's side exhaust tip on my '08 IS350 is hanging much lower than the passenger side exhaust tip. This is a stock exhaust and the car has maybe 67,500 miles on it. I haven't hit any potholes or driven on any rough roads so I'm not sure why this would have happened.
What parts are back there that could cause this? I know there is probably some sort of rubber hangar but I can't believe it would just break. I've replaced many exhaust systems and those things are always pretty stout unless they have a crap ton of miles on them.
Would anyone happen to have a picture of the parts used to hold up the mufflers in the back? I checked out mylparts.com and that helps some but sometimes a picture is worth a thousand words.
Thanks!
Old 03-04-17, 09:19 AM
Zmon
Zmon's Avatar
There are two rubber hangers holding the muffler up, you can check them both out and see if they're fine. But, as far as I know, most 2IS's I've seen have the stock driver side muffler hang a tad bit lower than the passenger side. I've seen this on my own car, and it was even more pronounced when I was running an aftermarket exhaust for a bit before I went back to stock. For aftermarket exhausts, some people have had success tightening the bolts up slowly to get the mufflers to line up a little better, while others had no success at all (I was one of these people, I zip tied the exhaust hangar on the Tanabe I used to have to lift up the driver side a bit)
Old 03-04-17, 09:33 AM
Soledad
Soledad's Avatar
Thanks Zmon. I'm just going to have to wait for a dry day to put it up on the ramps and see if everything is ok. It's funny, on my other cars this wouldn't be an issue but on my IS350 I want it all to be perfect.
Old 03-04-17, 09:53 AM
Aspect
Aspect's Avatar
Yup I have the same problem. Was way more obvious once I had my tanabe installed. Aside from zmon's idea of zip ties, I'm thinking of buying brand new rubber hangers which may or may not solve the problem.
Old 03-04-17, 09:55 AM
Zmon
Zmon's Avatar
Haha, I hear you. At the moment, I've got about a 3 finger gap on my driver side muffer, and about a 2.5 finger gap on the passenger side.
Old 03-04-17, 11:21 AM
Tungstn-IS
Tungstn-IS's Avatar
It's common on 2IS. I used zip ties on my aftermarket exhaust as well, like Zmon stated. I was able to get it even without them, but I think it looks better with the tips tucked up a little tighter into the bumper cutouts, so I put a large zip tie on each side to bring them up just a touch.
Old 03-04-17, 12:09 PM
Gville350
Gville350's Avatar
Though I didn't have one hanging lower than the other, I installed aftermarket exhaust hangers with a MUCH tougher durometer to help with the overall movement of the factory mufflers. I helped out ALOT! I can kick the mufflers now and they hardly move.
I believe these were the exact ones I purchased :
http://www.ebay.com/itm/2-Pcs-Double...item58dca79e98
Old 03-05-17, 07:57 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
My 2011 was like this from the day I took it home with 8km on it. :\
Jeff
Old 04-18-17, 02:21 PM
Soledad
Soledad's Avatar
I wanted to finish this off because I hate open ended threads.
I completely forgot about this problem until today. So, I looked around and under the muffler and sure enough the muffler mount had popped off the rubber hanger
How it popped off I have no idea because it definitely wasn't easy to put back on. Looks like these will be something I double check with every oil change.
The exhaust tips are now even again.
Old 04-18-17, 08:36 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
It must have been hanging much lower than mine was then, haha.
Jeff
Old 10-20-22, 04:27 AM
Mike121
1st Gear
Mike121's Avatar
Is the passenger side cat the same are the driver same can you used them for both
Old 10-20-22, 04:49 PM
2013FSport
2013FSport's Avatar
Received 1,527 Likes on 1,271 Posts
The hangers are all the same except those that come with the F-Sport exhaust.
PS - dish soap is the magic ticket for installing and removing these.
An open end wrench and prybar pop them off instantly with a dab of soap.
Defratos
IS F (2008-2014)
12
03-05-18 04:21 PM
myonoshane
Performance
11-19-14 09:01 PM
kazuto88
06-10-14 05:58 AM
BatKing
06-18-13 12:07 AM
phillygs3
Performance
24
06-27-08 08:58 PM
Quick Reply: Stock exhaust - driver side exhaust tip hanging much lower than passenger side
