Led lighting upgrade IS250 2006-2013
Help IS250 Gurus, this can't be rocket science... I have recently decided to change my lights from halogen bulbs to Led lights. I ordered fanless H11 headlamps and fanless 9005 bulbs for high beams a much brighter lighting option! After installing them I noticed that the headlights would not operate correctly. Unless the switch was turned to the headlight position the hight beams would flicker all the time the car was running, the high beams work when switched on and turn off then the headlamps are on however in auto the high beams flicker again. I have heard that the head high beams operate at a lower voltage when in Daytime Running Light mode. My question is does anyone make a plug in voltage modifier to account for this wiring issue?
