RCF wheels on '08 IS250?
Hey Guys!
I have a '08 IS250 M/T lowered with the F-Sport Springs (on the stock struts). I'm considering putting the staggered factory 19in 20spoke wheels/tires from a '17 RC-F. Has anyone tried this? America's Tire Co said it should fit with the stock suspension, but not sure about modified suspension with a 1in drop...
Hey Guys!
what are the wheel specs of the rcf wheels?
I have 19x8.5 +35front and 19x9.5 +35rear and they fit fine, even when I slammed my car on coils. With only a 1inch drop, your car will not have any issues.
M250 (04-02-17)
^^^^The specs are 19X9 +50mm in front and 19X10 +41mm in back. I have them on my ISF with 255/35/19 and 295/30/19. Not lowered. My rear fenders are filled flat. I will rub with folks in the back seat, or with a heavy load in the trunk. Otherwise everything is fine.
Lou
Lou
M250 (04-02-17)
Appreciate the info guys...
My current tires are 225/40/18 (front) and 255/40/18 (Rear)...the RCF has 255/35R19 (Front) and 275/35R19 (Rear).
Would the added width in the wheels/tires require the fenders/quarter panels to be folded in?
also depends on the offset. Personally, it's always a good option to have your fenders rolled or cut.
Running 255/40/19 in the front will definitely rub if you're lowered. Not really sure if you're stock height. I tried to run 235/35/19 in my front when I was dropped around 3" and it would not fit.
Right now i have 225/35/19 and 235/35/19 and I'm dropped 2" and it fits very well with a little room to play.
Better to be safe while fitting tires. Unless as they're changing your tires and you have your coilovers clamp thingys to change your height.
M250 (04-03-17)
Thanks everyone...appreciate the info. Was considering buying them from some dude online, but after the input I think I may have to actually test them first to save a headache later on.
