Lexus is250 Catalytic converter
Hello everyone,
i was wondering if there is any " DIY " for removing / replacing the primary catalytic converter ( the one attached to headers ) passenger side ( Bank 1 )
any DIY, pictures, instructions.. will be helpful
Thanks in advance
Thanks in advance
It's integral to the exhaust manifold. To replace it, you replace the entire manifold.
http://www.partsgeek.com/gbproducts/...ad=47433948492
Lou
Lou
Here's a guide for installing aftermarket headers: http://www.ppeengineering.com/docume...350Install.pdf
You can't exactly replace the cat itself, you'll just have to replace the manifold. Removing the bolts will probably be the most annoying part, I'm sure they're badly rusted. You'll most likely need to get a torch and heat them up.
Yes i know that i have to replace the entire manifold, but the problem is that the steps from (PPE) are not " Clear " , i was wondering if somebody did it and has some real pictures or instructions regarding this procedure ..
