Ever Remove Plastic Cover Under Back Bumper?
I just installed Megan sway bars and they look very cool painted blue. I want to show off the rear one by removing the plastic cover that is right behind it and under the trunk floor so the sway bar can be seen from under behind the car.
What is under the cover and is it functional??
Though the fins on the cover is not too pronounced, it was designed kind of like a diffuser to help keep the car stable at higher speeds. Is it truly functional though for this reason; maybe not. But Lexus might have designed it to help with the areo of car instead of stability. I doubt you'll tell a difference if it's removed though.
Ken167 (04-12-17)
Ken167 (04-12-17)
its an OEM diffuser and an under carriage for protection of objects flying up.
I have mine removed because I installed a custom diffuser. When I removed it, there were many small pebbles and debris inside.
Ken167 (04-16-17)
i would remove mine once a year to empty out all the debris that collects in it. gotta save weight lol. nah it would just irritate me that if i tapped it while cleaning i could hear all the rocks inside it
I took the cover off and underneath looks like the fuel evap unit and fuel pump--so I put the cover back on as it serves as protection from road debris. Im going to get the above cover, take the fins off and attach them to the factory cover!
i think youre better off going going to Home Depot and buying a sheet of aluminum or metal that fits and rivet or drill it as a diffuser. Those ebay things are plastic, poorly made, and over priced
