Water pump pulley bolts
There is a dedicated tool for holding the pulley in place to break those loose. I just stuck the fattest screwdriver I could through one of those holes and let it back up the pulley against the pump housing.
Is there a risk of damaging anything by using the screw driver, threads etc?
From what I understand...Leave the tensioner pulley in place to loosen these four bolts on the water pump pulley. Then loosen, remove belt, remove idler pulley, then remove tensioner pulley, then water pump pulley.
Here's something I found:
I'm going to be doing this soon...
