Hard & Pulsating Brake Pedal
I scanned the computer and got code c1201 The vehicle acts like it has a bad power booster. Could this be a common or likely prob with these kinds of cars since I've never had to do one before
I'm not sure about the code, but the hard/pulsating brake pedal may be due to your brake rotors being uneven. Whenever you change your brake pads you/the person you changes your brakes should shave off the brake disks because it will be uneven. If you don't shave it, then it can be uneven and cause uneven wear on your brake pads and then you could feel it in the brake pedal.
Possibly warped rotor(s). You can have them resurfaced or just get new ones.
http://www.rockauto.com/
They don't technically warp, but even pros use the terminology inaccurately. Things like lateral runout and disc thickness variation are more accurate. Rotors are forged at extreme temperatures, often 5 times that of any temp they'll reach while on your vehicle. To physically 'warp' a rotor would require similar tempuratures to those used during the forging process.
I currently have a front drivers side oscillation, diagnosed as irregularities in the thickness at different points in my rotor from extreme tempuratures caused by 'aggressive' braking. New rotors and pads all around tomorrow
I have the same symptoms right now pedal pulsing at any speed over 65mph, I feel it’s the rear rotors cuz my steering wheel doesn’t shake.
when I first purchased my car, I had that as well but after resurfacing rear rotors, it was very smooth, I just think I’m due for rear brakes. Pads and rotors.
blkstealthpaid4
37
01-27-09 08:01 AM
