help need to install rear camera install - wire color
I'm in the process of installing aftermarket receiver with rear camera for my wife's 2007 Lexus IS250. I need to tap into the reverse light wire near the dash for the rear camera. I assume the wiring is going through the driver side footwell fuse box but can someone tell me where and what color wire I should tap into? Thanks in advance for your help.
I did more search and came across this post.
https://www.clublexus.com/forums/is-...-guidance.html
Yellow wire under the dash is the correct wire to tap to get the reverse signal?
IIjzXXL
12-26-06 01:33 PM
