AC compressor not turning on
Old 07-17-18 | 06:38 PM
Htony's Avatar
Htony
Originally Posted by Tungstn-IS
If the a/c compressor isn't kicking on it is usually due to the pressure sensor, or being too low on refrigerant. It will kill the compressor to run it dry, so the pressure sensor will only allow it to kick on if it the pressure is within the required tolerance. So if the sensor is dead or the pressure seeped out, it will not cycle. Have you popped the hood and physically looked to see if it's coming on? It's in the lower right corner of the engine when facing the engine bay.
It's really hard to say what could be wrong with it without hooking up a manifold to the system and testing the sensor.
Jumping the gun? IMO, how about checking the fuse first?
Old 07-15-22 | 01:23 PM
KncklFKR13's Avatar
KncklFKR13
4th Gear
Default Ac pressures
Originally Posted by flynryan
With that being said, couldnt he just get a can of refrigerant and shoot it into the system? If the system is low and the sensor isnt letting it cycle maybe this will enable it to work. The cost if probably $30 or so. Probably the cheapest potential fix he could do.
It’s all good if your AC pressure is low but if your AC pressure is good and he introduced more refrigerant you’re going to over charge it and have the same problem
KyleH
09-26-22 08:29 PM
pdavid2204
LX - 3rd Gen (2008-2021)
12-06-17 09:29 AM
lostape45
08-16-14 02:25 PM
LS400BOY
04-29-13 04:46 PM
eli2k
01-06-08 03:27 AM
