Check VSC, NO CEL
Old 05-04-17 | 01:24 PM
Gocards6's Avatar
Gocards6
Default Check VSC, NO CEL
I have a 2007 Is250awd that has the dreaded check VSC, Pull codes and I get C1234. Yolk raw rate or something along those lines. I didn't see anything dealing with this particular issue when I searched. Car looks like it need rear break pads could this be causing the code somehow?
Old 05-04-17 | 07:28 PM
Arrta's Avatar
Arrta
According to the code it means Right Front Wheel Speed Sensor Input Signal Missing
https://www.engine-codes.com/C1234.html
Old 05-06-17 | 05:49 AM
mandyfig's Avatar
mandyfig
Or try to reset and it might not come back. Chances are high that it will not. Did you actually just had an emission test?
jpcdmd
11-21-17 10:23 AM
Luciano390
03-27-17 04:58 AM
tjwashow
03-03-14 10:15 AM
IS350rock
02-13-12 02:31 PM
