anybody installed the scosche LS2151B ??
thanks for the reply
i saw that the unit have an passenger airbag indicator that connect to the J54 harness with 3 wires... i know that number 6 and 7 which is PAON and P-AB are connected ... what is the third wire??
again thanks for helping...
Sorry for the delay getting back to your question. Unfortunately I don't have the answer for you. Having the instruction manual for the LS2151, it doesn't detail what exactly the harness wires connect to in the mating factory connector. It was a simple plug and play install with very little hardwire connections needed.
Where did you purchase this dash kit from? if it's Crutchfield, I would definitely give them a call. I have the Beat Sonic one and it's been working trouble free for close to a year now.
The BeatSOnic unit replaces the CD changer but keeps climate and radio controls in place. The LS2151 replaces the entire unit including climate controls. I originally looked at the BeatSonic piece but hated the look of shoving a double DIN unit all the way down to the bottom. I was ready to start surgery on the factory system but then Scosche finally came out with this unit. Made things a lot easier and installed pretty simply.
As you correctly said Pin 6 = PAON and Pin 7 = P-AB on the J54 connector of the Integration Control and Panel Assembly. The third Pin related to Front Passenger Airbag
ON–OFF Indicator Lamp is on number 4 and the wire runs to the J27 Junction Connector Pin 64 = IG+
Hope this helps
Problems with hazard light.
Hi, I installed the ls2151b dash on my Lexus is250 but since the installation I have problems with the hazard light that turn on randomly, did you experience this problem and how you solve it. Thanks.
Does anyone have any issues with the lack of rear speaker output? I've tried to adjust multiple settings and Scosche has not provided any technical support. I suspect it's a wiring issue. Has anyone troubleshooted this before? Thanks!
Hazard light problem
I have the same problem too. Did anyone manage to find a fix for this?
Hey everybody, just checking in to see if the hazard light issue was ever resolved. I installed this in April 2018 and it has worked perfectly up to a couple of months ago. The hazard lights now randomly turn on when driving down the road or even when parked in a parking lot.
Hazard lights coming on. Did anyone ever come up with a fix?
Did anyone ever figure out how to fix the hazard light issue? Mine is doing the same thing now. Thanks
Hazard lights on scosche
I have the scosche system for the lexus IS 2006 Model.
I experienced the same problem and started checking everything that is connected to the hazard lights.
alarm, locks, flasher relay and connections all over and so far what i think is happening is a faulty touch pad on the button itself. I unplugged the button board and so far so good. The only problem is that i cant turn hazard lights now. I'll try to solve the problem and keep you posted with pictures if you want. I'm thinking of replacing the touch with a switch on the circuit board.
The question about the rear speakers is easy.
The radio should make the right/left control of the sound but since the scosche system uses the connections for the rear speakers you can control the front/back sound on the climate control settings.
Hope it helped you guys
Solved the problem
For a brief introduction the touch for the hazard lights on my system is a capacitive sensor which has a lot of problems with external interference
so i took the sensor board out and put a little sheet of ferrite to prevent magnetic interf. And wrapped the board in high temp electronic orange tape.
Dont forget you can't tighten the bolts all the way cause it will make contact. Just leave a little play.
And clean the board with isoprop alcohol
Hope you solve ur problem!!!
ncwoody
05-26-10 08:10 PM
92GreenSC400
03-04-04 09:32 PM
