Hey, I have this same exact issue. after changing alternator Has the problem ever returned?? I read that it could be a possibility that you can yank the starter cord lose when removing the alternator?
Turns out the starter is connected to the same harness as the alternator wire. I followed the wire down all the way to the start. Then i pushed in the connector. Im sure it just came loose while i was pulling out the alternator.
