Fsport 19x9 squared fitment
i have a line on 4 new 19x9 forged Fsport wheels et 40. I want to buy them but am concerned about fitment in the front. What size tires can I run on that setup? I am on the stock sport suspension now, but may go lower in the future with mild springs. The lowest would be H&R springs. I do not want to roll or pull fenders. Thanks everyone!
Are you looking to run a square tire setup? Do you want to rotate?
You could run a slightly stretched tire up front and a slightly wider tire in the rear to still give it a staggered feel possibly..
I run a 8.5" wide rim (19") et 40 with a 225/35/19 up front and I rub when I full lock reverse.. which I don't really care about I just manage accordingly
You could run a 235/35/19 on the 9" wide wheel - I ran this setup on all 4 corners lowered on f sport suspension on my 08 IS250
What were the specs on your previous 9 inch wide setup?
I will run whatever tires work, I dont want to increase the circumference a bunch for power reasons.
i can also run the staggered setup that is available, but it seems like the 9s all around would look better due to offsets and I think they are slightly more concave.
I may use 255/35/19 rear or 275/35/19. Will the 275 fit? I'm considering 235/35/19 for the front. Is it safe to run 235 on a 9 and will it cause
premature failure?
id love to run 255 front and 275 rear if it would fit!
premature failure?
achvn
01-20-17 08:54 AM
stlgrym3
11-04-11 09:31 AM
