Hi, so just got done installing Megan springs and now I have that error message. I figured I'd adjust the sensors...simple enough right? No. I made many adjustments and nothing worked. I finally just went ahead and unplugged both sensors but it's still on. Any ideas? I read that unplugging the sensors would make the headlight adjustments inop but also get rid of that light not it's still on.
If you can, take a pic of these arms for us to look at. Disconnecting the sensor won't turn the error off, maybe pulling the fuse will but you should try to fix this issue though.
These are the best pics I could take with the wheels on. Front is angled a hair downward like in the diagram but the rear on the car does not match the diagram unless I'm not understanding it correctly.
