2011 is250 voice command button not working
hey everyone I'm new to this I just bought a 11 is 250 I just found out when I was trying to setup Bluetooth to my iPhone that the voice command button is not working it's not doing anything , anybody know how to fix this ?
I'll try and help. I believe there is a diagnostic you can get into via the nav unit. You hold (I think) the INFO button and turn the lights from off to parking 3 times (that's on, off, on, off, on, off) and the screen will change to a diagnostic mode. Obviously, you need to have the car on when doing so. I'm working from memory, so don't quote me for sure, but I believe there is a "button" test selection that will see if the buttons on the wheel are working. You press one and it tells you which is pressed.
Give that a try. You also might search for navigation diagnostic to get the exact sequence to get into the diagnostic.
luism24 (06-13-17)
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_0574_f5d6a9bccffb094f4229ddd44ad860d2cf13ee47.jpg)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_0575_187594135cf4b93783f85199dcb244d10f24848b.jpg)
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_0576_f932be2824145d4a8f727780de46baddbcb429f1.jpg)
I had this issue on mine NON NAV the buttons wouldn't work either. Ended up being the MIC wasn't plugged in on the upper dome light console. I took it apart to replace the internals to a new housing. I've must of forgot to plug it in. After that it all worked well.
Correction from post earlier. I think it's the Bluetooth MIC, not speaker in the dome console.
