Leaking transfer case
Hey, first time poster. I noticed a leak near the rear of my transfer case awd obviously. Does the is250 have it's own gear oil or does it share the engines oil? I'm a broke college student and don't have money to fix it but would like to know where the fill bolt is so I can top it off. And also is this a common problem? It's not a bad leak. Smells and feels like motor oil. Appears to be coming from the drive shaft seal on the back of the case but not 100% sure on that. Please let me know any information you guys have.
My understanding is the the transfer case shares the transmission fluid. I also have and AWD. I've changed the trans fluid a couple of times by drain and fill. I've looked for a plug on the transfer case and didn't see one. Unless I was looking in the wrong spot. I also have changed the differential oils to synthetic. If you do the front one it's easy accessing the fill bolt, by unbolting the steering rack from the cross member. It's a PITA the front on an AWD.
BinaryJay
03-07-15 09:43 AM
