Is newb NEED HELP BAD!
Hi Guys and Gals.
I am about to purchase my 1st ever Lexus :-) and need your informed help making a decision. I am looking at either the Is220d or the Is250 petrol both on a 2007 plate with around the 120,000 - 140,000 mileage.
Now i should make it clear that I'm coming up from a Vauxhall Astra so I'm not bothered about power stats ect both cars are going to feel like a rocket and a Bentley in comparison to me... But my question is this... ive looking all over the net and the insurances are virtually identical... But MPG!!!! I've been reading that the petrol gets better mpg than the diesel and then another one says vice versa am so confused. Which is the cheaper car to run
Now i know they say don't look at a prestige car and expect to run it cheap but I've fallen in love lol and like a beautiful woman nothing else will no longer do 😁 so which overall will be the cheaper car to run. Also does the 220d come in an auto??? I can't find one anywhere.
As I said newb here so sorry if this post has already been bought up ... All help greatly appreciated
Can't comment on the 220d, but the 250 shouldn't be too expensive to run aside from cleaning out the carbon buildup every 30k-ish miles. Other common problems on 2007 cars are that the nav screen (If your car comes with one) will unexpectedly die out and it is a really expensive thing to fix at the dealer. The other thing is if the roads in your area aren't paved well, the car will rattle due to a very poor dash design. Other than that, it is just regular maintenance. Make sure you follow the maintenance schedule and they should serve you well.
The IS250 typically averages between low to upper 20 miles per gallon depending on driving style and I'm almost certain that the diesel will get significantly better MPG if that is your focus. Best of luck!
Hi Newbie666,
please don't rush into getting the Diesel just on one recommendation!
i see you are in London and unless the diesel 220 is taken on a good sustained run at least every tank full then you might/will get into a world of pain.
the 220d only had a manual box ( bad move by Lexus!) and 6th gear is pointless in uk as it won't come into play until about 80 mph! So unless you like collecting points ( and I don't mean Clubcard points) 6th is redundant.
please don't just take my word for it but check out the LOC (Lexus Owners Club) a British based site with uk users of both cars and get feedback from both sides,
check this recent query same as yours. http://www.lexusownersclub.co.uk/for...e-l-questions/
cheers paul m.
cheers paul m.
Hi Newbie666,
cheers paul m.
cheers paul m.
http://www.lexusownersclub.co.uk/for...ooking-to-buy/
'Fraid to say here is another negative thread for the diesel version, I forgot about the head Gaskets going on these cars within the warrenty period and some having it done twice and even engines replaced! and the 5th injector can cause excessive black smoke to appear from exhaust, not very Lesus like!
please do lots of homework before getting a diesel and make sure you will be able to use it so it stays happy!!! cause you are right a unhappy Lexus is gonna hurt your wallet big time, whereas the Petrol 250 is one if not the most reliable cars out there.
more reading material here.
https://www.honestjohn.co.uk/carbycar/lexus/is-2005/
check out the "Model History" tab for good spec info.
Paul M.
Paul M.
Paul M.
Paul M.
Spoiler
seolstyle
07-19-06 12:08 PM
