20" rims
6th Gear
Can anyone tell me a 20" x 9 upfront and 20" x 10 rears will do with an offset of 40mm?? These are staggered wheels. Tires will b 245/35R20 upfront and 275/30R20 rears. Let me know if tire size(s) are okay.
I see your in Guam. Given the recent events I would invest that wheel money into bunker money and gas masks. Honestly though , someone will chime in with useful information soon.
235 would be max for the fronts. You are going to have rubbing issue and slow getaway from falling debris or artillery shells. Sway 20s with lightweight 18a or 19s for quick getaway.
^^LMAO
yeah for sure some lightweight 18's would help given the current leaders....
but if you go with 20's are you lowered, not sure if the fronts might be rubbing? the 40mm offset is for both?
i was rubbing alot with 225/35/20
I have 20's that came with the car I just purchased. They have 245's up front and 275's in the rear. Normal ride height. I do not know the offset yet as I have not pulled the wheels off. No rubbing under normal driving conditions.
The front driver's side has a small area where the paint has been damaged as seen in the photo. I can't positively determine what caused it though.
The second photo is jacked obviously but if you click on it I think it may "right" itself..??
Anyway these wheels work on the car with offsets of 35 up front and 42 in the back...
I do not care for them and they will be sold or traded.
I plan on getting 18'S
Mookiiee2 (07-28-21)
more info they are from a 2018 Rx350 factory wheels not 1 scratch
neillexx
Wheels, Tires & Brakes Forum
04-11-06 10:49 PM
