Anyone running 5x115 wheels on their car?
Hello guys, I've done a lot of google searching but a lot of the thread that comes up is regarding "will 114.3 fit on 115" on the Cadillac forums.
Seems like the consensus is that it "can" fit but not ideal.
Anyways, I just wanted to see if anyone personally is running 5x115 wheels on their cars with just a hub centric ring.
Thanks!
Thanks!
If the width, offset and hub size of the wheels is ok I don't see why they wouldn't fit with wobble bolts/nuts.
The studs and nuts won't wobble as they are tightened. The issue is you are going to have more stress on certain studs than others. Un-equal weight applied to the studs will be subjected to breakage.
Definitely. I'll carry a body bag too. It'll make the clean up easier. 🤙🏽
The hub rings won't help centre the wheels to the studs when you tighten the nuts the wheels will move and the studs will bear most of the force. Uneven distribution of the weight onto the studs and they will snape.
It seems that wobble/variation nuts would be the only safe solution to this.
therielalv
Wheels, Tires & Brakes Forum
06-02-14 02:31 PM
