Bluetooth Issue & Music
Hey guys,
This might sound like a stupid question, but I can't figure this out... I'm an IT and very techy, and I'm still having problems haha. I bought a 2009 IS250 AWD today (with navigation). I paired my phone via Bluetooth. My iPhone says it was connected, and even on the Nav, my phone showed up. I opened Spotify, and clicked the devices. Under "Bluetooth" it only shows my iPhone, and doesn't show the Lexus on the list. My phone calls work through the car, but Spotify's native streaming doesn't work.
Anyone have issues with this before?
I might do some more digging, but couldn't find anything on it yet. I appreciate your info!
Just found a post that says this: "Lexus models built before 2009 with Bluetooth support are limited to phone functionality only. The models built after this should have the A2DP Bluetooth profile, which allows for mobile phones with A2DP to wirelessly stream music to the car. "
So I think it should work, since I'm in a 2009. Now I'm confused
ComponY (09-28-17)
Anyway you could direct me towards the one you used? I see a few on their site.
Here is a link to one on ebay. I bought mine used off this forum for about half that price an it was a GREAT investment.
http://www.ebay.com/itm/A2DP-Bluetoo...ZSBW1I&vxp=mtr
I'm gonna try to poke around a little more, and if I can't get it to work, I'll probably buy it. Thanks for all the info and help, man! Much appreciated.
I believe the A2DP didn't come with media center till 2010. I'm not familiar with iPhone/iOS, but with Android, you can check to see if the Bluetooth connection is phone, media or both. I would check your phone to see if it shows media connection. I suspect your car doesn't have A2DP.
If I'm correct, you have multiple options to get used. You can use a 3.5mm to 3.5mm cable and connect your phone that way; I'm assuming your iPhone has the headphone/3.5mm port. Amazon has lots of cheap adapters that plug into cigarette port; some will connect via FM channel, others have 3.5mm port. I would use the 3.5mm port. A lot of will have phone connective too. A lot can be picked up in the twenty to thirty dollar range. I've read the cigarette port isn't isolated very well and will you hear some buzzing; I've experienced this using a USB charger and connecting via 3.5mm to listen to music, but it was during no music or low volumes.
There are a lot fancier ones, but they cost a lot more money. I personally picked up ViasTech SL3b-L. This unit just adds on to the factor media center. Still used factor Bluetooth for phone, but adds another channel for the Bluetooth streaming. The nice part, get to use all the factor controls--steering wheel, center console media controls--and will add some metadata on the screen. There are other similar units out there. I cannot comment on the sound and execution since I haven't received or installed the unit. What I read from others who have, works well.
Of course, you could just replace the media center will a different aftermarket navigation/headunit that does include all that stuff. Not a cheap option either. Won't maintain the factory look if that's important for you. There is a company that sells an adapter to change keep the factory navigation and install an aftermarket headunit; it's pretty pricey at over two hundred dollars.
I didn't research it enough, but you can also purchase a new media center from the people who the Lexus one. I forget the manufacturer name at the moment. I believe they had A2DP. The price was seven hundred dollars and had it's own DVD player. It probably is a minimal installation, but I didn't look into it getting one after the price and my needs and wants.
There are also some no-name Chinese media center replacements too. A few threads on them. But the general theme, there was an issue with passenger airbag indicator and, possible, questionable build quality.
This thread = https://www.clublexus.com/forums/is-...bluetooth.html
Seems to indicate 2010 was the first year, not 2009. If you end up using the Grom deal, my steering controls work for everything still. Volume and track advance. It just doesn't display the artist or song title, however I drive with my screen off anyways. That post seemed to imply the 2010 model and up don't display that information either. I liked the Grom piece because it just plugged inline to the CD player port and it was done. Mounted it behind the dash and it's out of sight out of mind. Connects before my system is done booting up every time as well.
... using the Grom ... It just doesn't display the artist or song title, however I drive with my screen off anyways. That post seemed to imply the 2010 model and up don't display that information either. ...
I was trying to say that some of the solutions will not display the track information. For some people, this will be important. Viastech solution is one that will display track information. I don't know if this is for MP3 files or similar on a mobile device or if it includes other sources such as Google Music, iTunes, Spotify, and so forth.
Like the Grom, the unit is installed out of the way. Integrated into the factory media system.
Here are some pictures Viastech posted on their website.
Viastech SL3b-L
Viastech SL3b-LBeyond that, I was just trying to be a bit more thorough on the options since it was something I was recently looking into. Figured might as well save someone some time in the general research area so he/she could focus on what appealed most.
