Alternator and Speedo Needle Going Out
This morning I smelled a faint burning smell under the hood. Took it to a tech who advised the alternator is going out--probably shorting out and may cause fire. Its still running for now with no CEL or battery warning light. New alternator installed will be about $400.
Also, the speedo needle is going out--sections of the needle are going dim--cant really see it in the pic. Its a minor issue though.
Alternator set me back about 300$ not worth setting your engine bay on fire, go get it done. As far as the needle, that's common its just some LED's and I see your over 150k so its nothing out of the ordinary, my needles been out for a while.
Great. At least you avoided the usual meltdown. Now as whitebeast said above, PM him. He repairs these cluster LED's and such when they fail, iirc. He can give you all sorts of different colors from stock too.
rakett
GS - 1st Gen (1993-1997)
08-21-14 04:05 AM
ArmyofOne
Maintenance
11-22-08 03:15 PM
