IS250 AFS problem
Fuse is ok but after changing Xenon bulb AFS does not work. I can feel the drive move when I push the headlight bulb in its housing.
On start up AFS is shown briefly as OFF.
Car is IS250 SE-L 2007
help!
help!
Had any suspension work done recently? It's very common to get the AFS sensors back on incorrectly when suspension work is done.
If not, I would check the links on the AFS sensors. They are both on the driver's side: one in front, one in back. They are little links behind the wheel hub toward the center of the car. Take a look and see if anything looks obviously damaged, failed or disconnected.
Let us know what you find as I don't recall any AFS just stopping by itself. Usually it is the result of suspension work.
Looking back, my ABS light was off too with TRC OFF and VSC but no check engine, pretty much the usual with anything wrong with the car. here's my thread: https://www.clublexus.com/forums/is-...-is-250-a.html
stephenwal
10-07-16 03:51 AM
vividracing
CL Vendor Products for 3IS
09-10-16 10:29 PM
