PCV Location for IS250
hello all. I am soon to be a Lexus IS250 owner and trying to gather as much information as I can on parts to replace when I buy it. I've read that the PCV is faulty and that it is a good idea to replace it, however, everywhere I check (YouTube,Google,etc.) it never shows the proper location. Can anyone briefly describe or show me with pictures where it's location is?
A web search tells that it's at the very rear of the left side cylinder bank. An unpleasant location. I had an opportunity to check it today, but I forgot. Attached is a picture. Note that the original valve is silver, but some cheap replacements are made from black plastic. Supposedly p/n 122204-31040 is silver.
If you’re facing your engine with the hood open. It is in the top right corner behind the cylinder block. It is close to the gas valve and the pvc hose is held by a pinch clamp.
If you search the famous big thread of “oil catch can experiment” you can see a lot of pictures of the pvc because it involves the pvc hose
