Lower Control Arm Bushings...
#76
The downside about using ramps and doing one side at a time (one wheel on the ramp under load) is the sway bar will fight you a little while pulling the rear of the arm down to R&R the bushings.
I suggest you measure left to right right to left from a fixed point the big nuts center... Record value. R&R bushing, measure again and place the new LCAB back where it was so the toe doesn't change. Then lower it on to ramps and tighten the nuts.
Thanks 2013FSport. Was going to follow up and question using jack stand on one side while the other side remains on ramp, and not having the one wheel under load while changing the LCAB. I would suggest taller ramps for some additional clearance however, seems the higher ramps to allow the vehicle the gradual incline to clear front, even more so in vehicle is lowered.
#77
2013FSport (12-15-22)
#78
Interested if any member that has installed the RC F control arm bushings (48076-24010 / Driver side) & (48075-24010 / Passenger side, experience a "creaking' noise, when extreme temperatures are encountered, 5° F and less (similar when non graphite poly-urethane bushings are used). If not the control arm bushings, perhaps it may be IS F sway bar (part # 4881153070) bushings (part # 4881553060) ?
Part # 48076-24010 (Left / Right 0 offset)
Lexus RC F Base 2015 - 2022
Lexus RC F Premium 2015 - 2019
Lexus RC F Track Edition 2020
Lexus RC F Fuji Speedway Edition 2021, 2022
Part # 48075-30030 (Left / Right 0 offset)
Lexus IS 350 2006 - 2013
Lexus RC 300 2017, 2018, 2022
Lexus RC 300 Base 2016, 2019, 2020, 2021
Lexus RC 300 F Sport 2016, 2020, 2021
Lexus RC 300 Premium 2019
Lexus RC 350 2017, 2018
Lexus RC 350 Base 2015, 2016, 2019, 2020, 2021, 2022
Lexus RC 350 F Sport 2015, 2016, 2020, 2021, 2022
Lexus RC 350 Premium 2019
#81
These were the correct parts listed for my year model. Will these not help the tire wear? I thought the main issue with the tire wear was the offset of the factory bushings. I thought the 0 offset was the goal. I would like to make sure if there is a difference I will return these and get the RC ones.
#82
Paul4949, Part # 48076-24010 (Left / Right 0 offset / Lexus RC F Base2015 - 2022 , RC F Premium2015 - 2019 , RC F Track Edition2020 , RC F Fuji Speedway Edition2021, 2022), I believe are made of a harder durometer rubber than OEM part Part # 48075-30030 (Left / Right 0 offset / Lexus IS 350 2006 - 2013).
#83
#84
The OEM +/- offset the car may or may not have been equipped (could be a zero 'no offset' on one or both sides) can correct a small amount of caster variance from side to side.
Caster does not induce tire wear like incorrect Toe or excessive positive/negative Camber.
Caster is what helps the car drive straight on its own. Factory is like 8°.
So, the increased firmness of the RC-F bushing helps maintain toe better which can help tire life... that said, if 20% of a cars life is spent in a parking lot, the edges will be destroyed. Run the front only pressure up to 38 40 psi to minimize edge wear.
If the insides are still getting chewed off, toe it in slightly from its current setting.
Make sense?
#85
Yes they are the correct PN by the book.
Make sense?
Make sense?
#87
What I meant to say earlier was. If I put the control arm bushings on myself and do them one side at a time with a floor jack, can I torque the bolts while on the floor jack but only tighten the nut on the control arm bushing then when finished pull the car upon car ramps and torque the control arm bushing nut to spec? Or does the whole car have to be level to torque the control arm bushing nut?
realsync1
12-14-22 11:00 AM
Salil022
09-04-11 10:09 AM
