Sunroof + Rear View Mirror Power Problem, Help!!
Hello all!
I have a 2009 is250 and I recently lost power / control to my sunroof, rear view mirror, and the lights above the sunshade / mirrors. What happened was my sunglasses holder broke and it wouldn’t stay up in the closed position. I had to remove the overhead console to fix it, but in the process I definitely had to disconnect a few wiring harnesses. I made sure I put everything back as it was but now I lost power to the above items. My first thought would be maybe I somehow blew a fuse in the process, but I read somewhere that there is not individual fuses for the sunroof, rear view mirror, etc, but rather one fuse to the entire overhead console. All the overhead lights are still working so maybe this isn’t it? Or does the sunroof and rear view mirror potentially have a separate fuse? Any thoughts or advice are GREATLY appreciated. Thank you!
Ben
Ben
So I ended up removing the overhead console again and reinstalled it and now everything works! Must have just been a loose wiring harness or something.
