Tires - 2012 IS 250 RWD
Old 11-22-17, 06:51 AM
  #31
Aspect
Aspect's Avatar
Originally Posted by SS1990
I had the Continental Extreme Contact DWS 06; 225/40/18 in the front and 255/40/18 in the rears installed today. The car drives significantly better!
Question - what is the minimum tire pressure (PSI) that I can safely use? I'd like to use towards the minimum in order to achieve the smoothest/most cushioned ride.
Stick to the OEM sticker recommended pressures on the door sill unless you want uneven wear on your tires or lower fuel economy etc.
Old 12-05-17, 01:03 PM
  #32
SS1990
SS1990's Avatar
To improve the ride quality on my 2012 Lexus IS 250 RWD, is it possible to run 225/45/18 in the front and 255/45/18 in the rear compared to 225/40/18 in the front and 255/40/18 in the rears that I currently have on the car? I know that having more sidewall will improve ride quality...
I'm going to stick with the Continental Extreme Contact DWS 06 tires. Continental will let me swap out for the other tires for free if I decide to (60 day ride guarantee).
I'M TRYING TO MAXIMIZE COMFORT, NOT PERFORMANCE. I PURCHASED THE LEXUS FOR LONGEVITY PURPOSES DUE TO THE AMOUNT OF MILES THAT I DRIVE.
Old 12-05-17, 01:52 PM
  #33
Gville350
Gville350's Avatar
^Stock suspension? I've read that some did fine on 45s and then some rubbed.
Old 12-05-17, 02:00 PM
  #34
SS1990
SS1990's Avatar
I'm going to be confirming my suspension at the end of this week, but yes, it is 99% stock.
Old 12-05-17, 02:54 PM
  #35
primavera
primavera's Avatar
225/45/18 might rub the front inner fender at full turn... 235/40/18 might be a better choice.
My solution to a stiff ride was a heavy 60~70lb bag of sand in the trunk, it seems to smooth out the harsh impact over potholes. That extra weight in the trunk also helps to drive RWD cars in snowy conditions.
Old 12-05-17, 03:04 PM
  #36
SS1990
SS1990's Avatar
How much sand should I get for the trunk? I'm going to try this before I invest in new 17" wheels and tires. I don't think I'll see much of a difference if I simply go from 225/40/18 in the front to 235/40/18...
If I go to 17" wheels, I will buy them so I can get 4 matching 225/45/17 tires (THIS IS THE EXPENSIVE ROUTE).
Old 12-05-17, 03:50 PM
  #37
primavera
primavera's Avatar
Lol buy a cheap bag of ice melting salt (I would probably double bag it) put it in the trunk and see. If not enough get another one. I carry a heavy tube filled with sand, don't know exactly how heavy but it's at least 50lb
Old 12-05-17, 06:10 PM
  #38
SS1990
SS1990's Avatar
Do you keep the 50lbs in your trunk year round? Do you have 18” wheels? Improve ride quality???
Old 12-05-17, 07:10 PM
  #39
primavera
primavera's Avatar
I'm on 18'' and yes I keep extra weight in the trunk all year round, it doesn't affect fuel consumption either.
Old 12-05-17, 07:13 PM
  #40
SS1990
SS1990's Avatar
I think I’m going to get a couple hundred lbs of sandbags to keep in the trunk then. Fingers crossed it improves ride quality!!!
Old 12-05-17, 09:35 PM
  #41
flowrider
flowrider's Avatar
Received 1,896 Likes on 1,337 Posts
Of course it does
Lou
Old 12-06-17, 09:35 AM
  #42
primavera
primavera's Avatar
Originally Posted by flowrider
Of course it does
Lou
How? 50~60lb is about the weight of a big baby or a skinny teenager in the back seat, how does it affect the fuel consumption? lol
clambros
04-27-23 10:47 PM
rvkbj2345
Wheels, Tires & Brakes Forum
01-21-14 07:18 AM
ephisig764
10-08-11 11:49 AM
MSMLexIS
11-17-05 06:01 PM
LexusPia
11-07-05 10:13 AM
Quick Reply: Tires - 2012 IS 250 RWD
