Will Mazda 3 rims fit my friend's lexus is350?
Old 11-20-17, 02:18 PM
samisheikh
samisheikh's Avatar
Default Will Mazda 3 rims fit my friend's lexus is350?
As the title says, my friend has an IS350 2006, and I was wondering will my old mazda 3 17" rims fit?
Here is the info on the Mazda rims:
Bolt Pattern: 5x114.3
Offset: 17x6.5J ET52.5
And AFAIK the Lexus IS350 comes factory with:
Offset: 17x8J ET45
I read on another forum that a guy got away with using 17x7" but I'm wondering if 6.5 would work or it would be too small?
Thanks,
Old 11-20-17, 03:02 PM
primavera
primavera's Avatar
They might fit since they share the same bolt pattern but they won't be hubcentric. Mazda center bore is 67.1mm and Lexus is 60.1mm. The only way to find out is to mount them and see if they clear bigger front caliper on Lexus.
Old 11-20-17, 03:34 PM
2013FSport
2013FSport's Avatar
Received 1,511 Likes on 1,257 Posts
^^ Nailed it. +5
But a 6.5 rim is to narrow. If rwd, those are 8.5" for a 255.
If they fit, they make center spacers which should used to fill in the difference so the studs are not taking the whole load.
The 350 calipers are pretty big. Trial fit is best.
Old 11-20-17, 05:15 PM
samisheikh
samisheikh's Avatar
Ok thanks primavera and 2013Fsport, it was a longshot but now it is confirmed.
Old 11-20-17, 05:23 PM
samisheikh
samisheikh's Avatar
Will 17x7.5j ET44 fit for IS350 RWD?
Edit: Coming from a Ford Fusion Hybrid 2011
Old 11-20-17, 06:53 PM
primavera
primavera's Avatar
You might have better luck with Ford wheels, pretty much same configuration as Mazda, just an inch wider. Try them on and see if they clear front brake.
https://www.wheel-size.com/size/ford/fusion/2011/
Old 11-21-17, 06:47 AM
Aspect
Aspect's Avatar
A little off topic, but I'm using the 17" Mazda CX5 wheels on my IS250 with a hub ring and it fits. Looks like enough space for the 350 calipers as well
DCLexus
31
07-28-11 11:24 AM
xposure
11-12-08 07:56 PM
Warrenbic
Suspension and Brakes
05-23-08 01:41 PM
m0t03
Wheels, Tires & Brakes Forum
03-11-04 10:19 AM
m0t03
03-02-04 11:10 AM
Quick Reply: Will Mazda 3 rims fit my friend's lexus is350?
