Mirror Puddle Light +12v on Right side
Does anyone know if the +12v wire for the puddle light in the mirror on the right hand side can be found easily in the footwell once the plastic trims are removed? I need to tap into this to illuminate extra lights. There is a bunch of wires coming in from the door into the car but lots of wires. Does anyone know which one is puddle light one?
There are two yellow wires going to the mirrors, behind the front door panels, I know you can tap in to those.
I recently wired in under-car puddle lights and tapped them in to the rear dome light. This is ideal as the lights come on when you're near he car, unlock the car, open the door and can be manually turned on with the dome light button. That is where I would recommend running them.
Also, while testing the 6 pins on that connector with a multimeter, a few times the tip of the probe slipped and I got a few small sparks when positive touched negative. I hope I haven't blown anything. I tested everything and haven't noticed anything not working yet. Mirrors are all working etc.
Anything mounted in plastic will have its own unique ground so the puddle lights fit in this category. That said, they may not tie back to a common ground that you know of as the chassis ground. In short a module with a switch does not have to have that switched pole tied to a common ground. Make sense.
Also, if you do this, you should run a reed relay or a solid state relay so the circuit is not compromised by the extra load even though it is just LED's....
There is a red controller box inside the door panel which i assume controls locks and windows. Does anyone know if there is a always on wire in there somewhere?
I've done alot of lighting mods on this car and the interior and puddle lighting grounds are active from a control box. This provides the dimming features. For the puddle lights, I just ran wiring from door back in to interior when I did my LED door handle lights on all four doors.
There is also the side front lighted scuff pad prewired plug for the plug and play on certain year 2IS (I think up to 2010). This may only be activated when door is open though.
vboi4life
06-11-12 09:55 AM
