Electrical Issue-Now Weird Things are Happening...
Hey guys,
It's been a while since I've been on here. Hope everyone is having a great holiday season so far!
So a few weeks ago, my usb to cig lighter adapter failed and blew up...literally. Seconds after, my bluetooth audio device started sparking and spewing smoke.
Now my aux port won't work unless I have my phone plugged and charging in the cig lighter.
I'm hoping it just did some damage to my aux port and replacing it will solve this weird issue. Could it be possible that my radio unit got fried in all of this? Would be an expensive fix
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I'm hoping it just did some damage to my aux port and replacing it will solve this weird issue. Could it be possible that my radio unit got fried in all of this? Would be an expensive fix![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Honestly, I'm not sure why plugging your phone into a cig lighter (I assume with a 3rd party USB adapter) would have anything to do with the aux port to the radio. So you had your Bluetooth device in the cig lighter I assume? It blew up and your aux port quite working? If that's the case, check your fuses. Again, I have no idea what your cigarette light has to do with the Aux port, but maybe some wire got toasted under the socket and pushing a charger in gets a connection. And yes, it would be an expensive fix if you have to repair the radio.
I have a Dual USB adapter in the center console. BT device and phone charging cable were both plugged in. Been riding like this for over a year with no issues.
Since the USB adapter and BT device sparked and burned, I had to go back to a conventional AUX cord into the port and my phone. That's when I discovered the head unit would not go into AUX mode unless something was drawing power from the power outlet. I confirmed this by getting a new USB adapter and plugged my phone into it to charge. When phone was charging, head unit would go into AUX mode when AUX cord was connected to phone and AUX port. Pull out the USB cord from the phone, speakers make a pop sound and then head unit switches to Radio.
Something weird is going on...I know...
I don't have a OEM bluetooth audio system. So I have a BT device that plugs in AUX port and needs to be powered by USB.
I have since bought an bluetooth FM transmitter device. The high pitched noise is pretty much gone now but when there is no music or connection, the high pitched noise is there. Definitely an electrical issue going on related to the AUX. Most likely in the radio unit. Anyone have suggestions on how I can troubleshoot this? My plan is to removed the radio unit and inspect the circuit board to look for any obvious damage from the previous sparking I had.
Your getting a lot of back ground noise when plugged in to the aux cord with a Bluetooth device ?
if that’s the case buy a 3.5 filter from amazon. There other threads on it. Once I installed the filter all the noise went away.
I'm currently using a FM transmitter bluetooth device and the background noise is barely there anymore but there still is. It sounds like there is some faint white noise coming from the speakers even when the radio is off.
JasonSong
09-30-17 11:25 PM
