DEPO Headlights
#168
Can you post a link to the led driver you guys are using... and at this new driver voltage will it damage or over heat the LEDs...cause that' very easy to do running them at higher volts
#169
https://www.ledsupply.com/led-driver...uck-boost-mode
I just talked to the guy at LEDsupply. This driver is dim-able via PVM 5 volt dimmer wired to the white wire. He doesn't carry the 5 volt PWM dimmers tho. He agreed that a 350ma is conservative not knowing the LEDs types we have. He also said a constant current style driver is what we need. So we are are the correct path. I feel we are good to go as to not over driving the DEPO lens via this driver I bought.
Tex
#171
The LEDsupply guy mention another driver that can work as well,
https://www.ledsupply.com/led-driver...ost-led-driver
with Internal Trim and External Dimming. You could use this driver and trim the output as desired, and then use the dimming circuit to dim the unit. To activate the Dim circuit you would need to Break the connection trough the dimmer circuit "like aka via a relay" when headlights are off, and then close the circuit when headlight are on to activate the dimmer circuit. Both outputs would be adjustable this way, the non dim one and then the dimmed one. I may switch to this style myself, and have adjustability on both Bright and Dim. its more money 19.17 each plus the wiring harness with pot for 4.99 each. you need 2 of each for the project plus a 2 relays to activate the dimming circuit if you choose to go this way. Its entirely possible the China lower supply voltage when Dimming might work without having to use the Dimming Pot. This guy at LEDSupply agreed that my flicking is caused by the output voltage is barely enough to make the LEDs light up when dimmed "Lower Voltage" is being supplied from the China controller.
Just an update, I ordered these components tonight. I will update once I begin testing.
Tex
Tex
#172
https://www.ledsupply.com/led-drivers/mean-well-ldh-series-cc-step-up-boost-mode
I used the $10, up to 30W, 350mA version it's twice the capacity I need but better to be safe. You can try the 500mA version to see if that output is better. That would be stepping the LED to to about 1.5W each, which I think is pushing it.
#173
https://www.ledsupply.com/led-driver...-dc-led-driver
What is the difference in this one and the others?
#174
I got the head lights installed . Left and right lighting output point out not even can they adjustable or I have to return them?What is the best HiD conversion kit close to the oem light ? Can I do 6000k? What is recommend for the fog light 5000k?. Thank you all!
#175
Semantics this one, that one ... we are on the target and zeroing in to its Bull’s-eye. I am sure all three drivers will work fine as long we don’t exceed 350Ma and comply with min voltage to light up.
I am pretty sure with the new one this guy recommended I can get the combination of items to get the features to work as I planed. We will see how it goes. I changed because finding 5 Volt PWM dimmers to activate its internal dimming are expensive.
Take care are and I will post this weekend on the findings I get.
Tex
#176
It might tho to call that guy at LEDSupply and let him walk you through the differences. There is a formula based on the number of LEDs you are powering to input voltage required.
Hence you may have found another one that can work.
I truly believe we / you are just talking features between the units. They all 4 now look to work in our situation. The question is the logistics of how to dim. How to make the unit dim and then brighten up. So far all of these can be dimmed. How to get the dimming to work with the car and not pulling over and twisting a ****.
I went with a China controller. The bright dim works now. It has another feature it flashes the Led with the turn signal. This led me to discover, when dimmed, I have flickering on the LED strip when being flashed with this new led controller. With the Depo controller I did not have this issue. But the brightness output was to low for me. When dimmed it was worse.
So so full circle we are. Now which driver.... is the question.
Depenss on how your plan to dim your headlights. If using the China controller like I did. It’s works with the driver I bought. However the flasher feature I am not happy with.
So more adjustability I seek so I bought the adjustable trim output one and harness that has a pot on it. Now I have options. Sinister2c may habe the correct driver and work with a china controller. He bench tested it and it appears to be ok from a power supply. In the car it may yield a different result. I hope not tho. yeah clear as mud.
So back to your question: I approach it how are you planning on making the dim function work? Are you planning a China controller, maybe have a flasher DRL with turn signal?
or ditch the China controller and go another way.
I would work back from answering that question and lead you to which one. Of if you have time, I share if this new driver works this weekend with or without the China controlled is yet to be determined.
remimd me of let’s make a deal, door number 1, 2,or 3?
inam trying door number 2 this time and will see what’s behind it .
Take care... once I get it combination working as I like it I will report back how I made it happen. Good luck
Tex
#178
Gotcha, you could then accomplish it many ways, but I see one of the easiest is to
option 1.
1. Buy a driver with anolog potentiometer dimming,
2. Tap key switched power and fuse it.
3. Use a replay per headlight to close the dimming circuit when headlights come on triggered by the power to the low beam. This would close the replay and complete the dimming circuit. You would have adjustable dimmed LEDs via the “Pot”. It’s a little clumsy with the two relays but simply it will work. If relay fails you have bright LED on the failed side when headlight is on.
Option 2.
1. But simmer with the trim to lower or raise output like I just bought.
2. Buy 12 dollar amazon China led controller module and wire it where the supplies battery power and the key switched power comes on together. This will send power to the led driver full brightness.
connect the trigger wire to the low beam on one headlamp to trigger the dimming function. Leave the turn signal flashing option disconnected.
done...
break out the green power wire to the led driver at the OEM connector headlight side and that where you tie the output of the China controller, and tap the low beam wire on the car side of the headlight connector for the signal to dim to the China module.
Simple and I know it works because I have that now.
If you wait just a few more days, I report back if this new dimmer works as I hope.
. Hope this helps
tex
#179
Best kits that’s like asking Lexus or yoya , ford or Chev
but the temperature would depend what kind of driving you do, in low foggy conditions, lower temperature 4500 ish range. If clear not low vis days that much. Then 5500-6000 is really white. That’s what I prefer.
Now ballast, the quality comes how fast they warm up.
If you run 35 watt ballast then you will get true color from your bulbs, but 50-55 watt ballast will cause your bulbs to not last as long and come down in temperature like 55 watt with 6000 temp would be 5000 ish.
I haven’t seen the oem Hid personally. I ran 5500 bulbs and 35 watt ballast both fog and headlight until I retrofitted and was happy.
Good luck...
#180
And my headlights come in Tuesday along with new projectors so if you give me a week or two..I'll be retro fitting Morimoto mini D2S 4.0 projectors but using 5500k d4s bulbs and the factory ballast mounted to the bottom of the headlight housing in the factory location... so back to the led driver talk.. can I not just use the 7$ led driver and run the dimmer wire that comes from the driver to my low beam wire, so when it sees 12volts it dims the LEDs?
