Ty CL veterans, advice on another pic- camber/suspension
Another six months it will be 2 years since I own this car I'm still learning the basic of this vehicle for my exuberant daily driving. Knowledge is priceless and thank you veterans once again for the help, here are a few more pics I had questions on
1-
Notice that the censor is not straight up between those two bolts like on the passenger side is that a problem?
2 -
Which one is the camber bolt?
3 -
the oil here is the that bad and what should I do or check for?
I didnt think they were adj from factory. You can move x member to equalize.
Bolt will move up with wheel so cannot rub.
Wash off all oil 1st then check for leak (as stated above)
Zip ties can fail. Try to get the stainless ones.
What all has been done to this? It looks like a *newer* inner tie rod that wasn't installed with the correct clamps.
That leak is much higher up. Start from the top down and when cleaning either remove the belt or attempt to protrect it from solvents and grease as these contaminates can make it squeak later by allowing it to slip on the pullies.
