Check VSC, abs, trac control, and brake lights on after alignment
Got an alignment done on my 08 is250 after getting my wheels mounted on and not even after 20 miles of driving, my check vsc message, brake, abs, and trac control lights are on. I looked it up and read some threads on the similar issues, but no luck so far. I've went to autozone and oreillys to get my codes check but they cant pull anything up. I read something about not getting a steering angle reset after the alignment...but I'm not exactly sure what is wrong with my car even if thats the case. And its not the gas cap. I do feel a difference when driving. The car isnt as responsive, doesnt cut corners as well, and when I'm on the highway driving on one of those ridge things (i have no idea what its called), my car is a lot harder to control. I have an OBD2 scanner coming in the mail soon, but I wanted to see if anyone has any input on whats going on.
and unless you have a Toyota specific or special code scanner (cant remember the specific names), you wont be able to read these codes. this is apparently a "chassis code" and will not be picked up by generic code scanners. autozone scanners pull mostly engine -specific codes
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
on the wheels? currently about 100. I bought them new. The tires? Not more than 1000 on the one I've had on the longest so far (so many nails
rip) . I haven't had a problem until the wheels and alignment being done. The wheels are lexus wheels for a newer IS model, so I dont think they are whats causing the issue
^^^truth. just did this myself. you can see a pic of the sensor, itself, on this thread: https://www.clublexus.com/forums/is-...lications.html . I didn't have to redo any of the abs wiring, but I did have to reinstall the sensor by itself, which was a PITA. thought I was gunna break it (which I did, and had to, when removing old one). if you need a new sensor, when you search they come up as like $100+. do not buy those unless you wanna waste the $$. I got cheap ones that work just fine from carparts.com
rfopt
ES - 5th Gen (2007-2012)
12
07-30-19 12:58 AM
DruMnBaSS
09-03-09 10:01 AM
