Rims size
What is the best fit rims size for my 2012 Lexus IS 350 I want to go 19x9.5 in the rear and 19x8.5 in the front, I was told I would need spacers because of the big calipers and that I would need to roll my fenders and stretch out my wheels? I don't like that camber look!! I just want a clean flush look! Pls help what will work tire size? Off set? And width? What a good tie size to? 19 ? 40? 45? 245? I don't know what I need! need help
Tons of members run these sizes without any modifications to their fenders. You may need to do a little work on the fender liners but nothing crazy. Look at the wheel thread sticky at the top of the page and also browse the “ will these wheels fit” thread and you will find all your answers. 35-38 offsets are pretty conservative and will sit pretty flush.
tmlexis350 (01-23-18)
Those tire sizes as mentioned are very common and you shouldn't need any modification depending on how low your car is (if lowered at all)
I run a 35 offset front wheel with a 45 offset rear and the front is flush and the rear is just slightly tucked - but doesn't rub when i hit dips
tmlexis350 (01-24-18)
BatLex
Wheels, Tires & Brakes Forum
05-19-07 01:13 PM
