side mirror problem
Hello all.
I was changing out my puddle lights on my 2006 IS350. I got a little impatient with the mirrors and used a little too much force. Once I snapped the mirror back in place, I noticed part of the mirror had a blue tint on it. Did I break something inside my mirror? Please help!
The liquid or photoelectric gel inside the mirror is broken, typical when too much force is used to snap it back in place. Had the same thing happen on a 2nd gen RX then started to leak. Probably find a non auto darkening one cheaper than original if you aren't too concerned about it. It might be heated as well depending on the option for 06.
The liquid can stain the paint if it starts to leak.
Search the forum for similar issues on other Lexus vehicles.
Good luck, I'm sure others will have some thoughts as well.
Yup, I have the same issue on my 06 is350. It's how I purchased the car.
Luckily, Lexus sells the replacement mirror itself, without purchasing the whole mirror assembly
https://www.lexuspartshub.com/oem-pa...***-8796153250
Other sites have it for less. Heck, maybe the dealer might be cheaper!
StanleyR (01-24-18)
https://www.ebay.com/itm/DRIVER-LEFT....c100705.m4780
If you want to ensure you wont crack the glass when re-installing theres a very easy solution I've used many times..
The black plastic outer ring can be taken off rather easily, then the glass separates from the backing plate (held by some putty). Reinstall the backing plate which is what needs to force to pop back in, reposition the glass and secure it with the retention ring. No excessive force ever placed on the glass.
If you are not concerned with the auto-dimming, I've used burco replacements with good results. Very affordable and have heated and non heated options. Good luck.
Or spend a few minutes searching ebay and find a cheap mirror to rob the glass from such as....
BADFNZ
02-15-10 02:12 AM
