2006 IS350 jump forward after hard brake.
Hi, I have 2006 is350, it has 70Kmiles. When I do hard brake, the car is stop and sudden jump forward right after.
But if I stop gradually slow, nothing happen.
Is it something wrong with the transmission? Why it's happen like that? Does it happen to any body?
Thanks,
Eric
Thanks,
Eric
Are you using ECT PWR mode? The car usually does this in power mode, it has aggressive downshift and holds the gear in case you need to step on it again itll already be in gear for you to take off.
Thanks,
Eric
Thanks,
Eric
BTW, I check the ECT is at normal mode, I tried to use PWR mode, the problem was worst, at ICE mode the problem still there but less.
That happen when my car is warm up. The idle at normal term.
Thanks,
Eric
Did you measure what was drained and only put back in what was removed. There is a method to doing a proper drain of the tranny that simply dropping the plug will not accomplish. If you only drained what came out after dropping the plug, you only removed, I believe about half of the transmission fluid. If you added back the capacity of the transmission according the the specs, you overfilled the heck out of it.
Thanks.
Yeah, sounds like a trans fluid amount issue. Probably too much fluid. If you watch this video, do the sequence correctly, drain the excessive fluid out of the drain plug, it should hopefully fix itself with HOPEFULLY no long-term consequences.
https://www.youtube.com/watch?v=Aa5p4Sx9apU&t=271s
Fughazi
08-12-23 12:50 PM
Slashael
12-17-13 02:43 PM
