Cam shaft position sensor B
Ok so I recently did my alternator on my 2007 lexus is250, and didnt notice this sensor when i was moving the harness to make room to get to the back bolt. As I moved the harness over the wires to this sensor pulled out. I have been trying to place the wires back in, but they just keep ooping back out, any ideas please?
-mikey
-mikey
[QUOTE=2013FSport;10100767]Buy a new sensor!??
rockauto....[/QUOTE
the wire from the wiring harness came out the connector to the sensor, or the plug , the sensor is fine
rockauto....[/QUOTE
Can you get the connector out where you can remove the pin? I'm not familiar with this connector, but sounds like you need to add a new wire to the connector where you can assure it won't come out and then splice it into the old wire.
-mikey
-mikey
how do I change it
sr5guy
02-19-18 04:02 AM
