Need help on air bag indicator light on?
hi guys, I need your help on how to figure out to turn the air bag light off? For some reason last few days my is350 just pop the air bag light on, what can I check? I tried to disconnect the negative battery still didn't work ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
https://www.clublexus.com/forums/is-...ion-tsb-5.html
give that thread a read, especially the page I linked. Some members have had luck checking and retightening the airbag harnesses, some have had to replace the wiring harness for the car which is quite expensive as it requires them to open up the dash and etc. Is it just the airbag light on in the dash? For my personal experience I had that light but also a Passenger Airbag Off light beside the hazards button which was because apparently the passenger seat cushion sensor went bad which was also very expensive fix as well as they had to replace the cushion which costed me like $1700 CAD and then installation labor
My light was on a couple days before I did the airbag recall...luckily it went off the day of the recall and went back on the day after. I simply took it back and blamed them and they fixed it. They told me it was the driver side knee squibb just like the post above from Aspect. Go ahead and give that shot, it should take only 20 minutes or so. Light hasn't been on since.
Thanks guys for all the help, i did follow the link aspect gave, and sure enough that my passenger knee air bag plug is cause that, I didn’t know how to unplug it, and I couldn’t unplug instead of unplug it I squeezed in more and no more light on for three days now
thanks everyone
RWC SC400
SC- 1st Gen (1992-2000)
48
01-06-21 06:53 PM
