Too many lights on dash
2006 lexus is250- check engine light , traction light, tire pressure light are all lite up. I dont have stock tires on my car, how can i take that light off? Check vsc popped up on the dash too... Also, when driving feels like it takes a minute to pick up speed, that happens off and on... It was check with a computer cylinder misfire but i changed the ones it says but still pop up. Help...
Lexusgal06 (02-28-18)
Super Moderator
"Check VSC" comes on whenever the check engine light is on, so don't worry about that one unless it stays on after you fixed the CEL. Like Gville350 said, you need to read the codes to see why the check engine light is on. As for the tire warning light, you don't say whether it is "low tire" or "check system". If "low tire", add air to your tires. If "check system" you probably have a dead battery in ones of your TPMS sensors. Or, if you have aftermarket wheels with no TPMS sensors, see this thread (from our FAQ) https://www.clublexus.com/forums/is-...pipe-bomb.html
Lexusgal06 (03-01-18)
I've had the same issues. I had no TPMS sensors on my tires so the low pressure light was always on, along with the warning light. Have never been able to get rid of the light. I've also had VSC with traction light come on and had the loss of power, dealership could never figure it out. So I live with the Christmas tree dashboard hope you find better luck.
Jackson850
ES - 5th Gen (2007-2012)
10-14-18 05:40 PM
Jeffrimerm
02-13-14 03:42 PM
