11-13 headlight "computer"
My car is a 2006. I am purchasing a set of oem headlights off a 2012. The seller is not including the hid bulbs or "computer". I wanted to make sure there isn't more than a ballast and bulb on these lights. Will the lights be missing the "computer" and not be able to aim? Or can I just put a hid kit in these lights and expect them to aim property? Thank you!
^^^^^Sewell used to be a sponsor here. Lot's and lot's of positive posts about them. Do a search and see. Here's just one:
https://www.clublexus.com/forums/is-...or-1200-a.html
Lou
Lou
TRS has those Denso replacement KDLT003, DDLT003 that @2013Fsport is referring to for cheap, $65 for a universal ballasts that can run D4 and D2. Plus its supposed to be OE quality. The ability to run D4 or D2 is worth it. Lots of better and cheaper D2S bulb options.
Ok, sinister.! Thank you. I'm making sure that they screw in to the bogtbo of the headlights, as if they're oem.. Toyota/Lexus places their ballasts into a sort of black housing, that is shaped to the bottom of the headlights
https://www.theretrofitsource.com/hid-parts/hid-ballasts-oem/oe-replacement-denso-ddlt003.html
Are you referring to these?
Do you know there are other pieces , aside from bulbs to make these work? It looks as though they have the housing around them.
they will bolt on but the bulb harness needs to be disassembled to fit thru the projector on HL. This has to be done for all ballast on this light. There is a video on the 2011+ change out thread.
That explains why there are so many unloaded aftermarket and used ones out there. The 2006-2010 HID AFS all usually sold loaded with ballasts, even aftermarket.
