Fault code
10th Gear
Hi all.
I recently purchased a BlueDriver OBD2 sensor and recently ran a test.
I have a 2011 is350.
I keep getting the code p1378 for a large number of modules.
1 Body No. 3 Trouble Codes:
• P1378: Check report for description.
1 Body No. 5 Trouble Codes:
1 Combination Meter Trouble Codes:
1 Air Conditioner Trouble Codes:
1 Combination Switch Trouble Codes:
1 Remote Keyless Entry Trouble Codes:
1 Power Trouble Codes:
1 Master Switch Trouble Codes:
No report for description comes up also.
I have cleared the codes and they return again.
engine running or engine off makes no difference.
Any ideas
thanks in advance
Phil
Any ideas
thanks in advance
Phil
10th Gear
Checked battery voltage and alternator. All was good.
Contacted the obd2 scanner supplier and turned out to be a bug in the app software. They will be updating the issue in the next version upgrade.
430keeper
12-15-14 10:57 AM
