My Lexus is acting strange. It will start every time in PARK, but sometimes the DRIVE light lights up with the PARK. Also, if i leave it sit for a while idling in PARK it will sometimes make a funny sound and then shut itself off.
In NEUTRAL it sometimes PARK, NEUTRAL and DRIVE are lit up.
It shuts itself off when I shift through NEUTRAL (for example going from park to D), but i can move it back into NEUTRAL.. it starts and then i can shift it back down into D and go. Works fine in D, but when I go to park shifting back through neutral it shuts itself off again.
in park
in reverse
Sounds like something is off on the park/neutral position switch.
Had the exact same issue few years back, while driving it just went crazy. It turned out the be a heavily corroded neutral position switch. The switch needed changing and so did the wiring connector.
Side of the trans is the first place I'd look. And corrosion is a probable suspect. Have a new switch handy and be careful as moving the lever out of park by accident could allow the car to roll and crush you.
The switch is easy to align w a small pin or dowel.
