3mm Spacers - spacer uses help me out!
I’ve been looking into a set of wheel spacers lately for my rear wheels. I had 35 offset wheels fitted and they rubbed quite a bit hitting dips so I reverted back to 45 offset. I was thinking if I could get just a bit more flush using a small set of spacers it might be a worthy investment. I’ve read a few threads so far and it seems as though people run many different sizes of spacers, some with good and some with bad opinions. I definitely do not want to buy new hubs or adapters with longer studs, so I was thinking a set of hubcentric 3mm spacers would do me nicely.. just wondering what others thoughts are.. and if some people are out there running 3mm spacers it would be nice to get some feedback.. the spacers are not a necessity by any means.. my car already looks great with the offset of the wheels. I’ve ripped on people before for using spacers before so feel free to flame me if you’d like.. i feel like anything over 5mm is asking for trouble.. but I’m no expert
SeanO (03-30-18)
SeanO (04-02-18)
Hey Sean, if you don't feel like paying big bucks for Eibach, H&R, KW, and 3.0mm is all you need you can try NovusTech spacers. I hear they are made locally in Kitchener.
https://www.instagram.com/novustech/
Oddly enough over the weekend I dialed down the amount of rear camber in my rear suspension to gain me slightly better tire wear (just had an alignment) and with my 5mm spacers with a 35 offset on my rear wheels I'm too close to the rear fenders for comfort. So I've got on order a set of 2 3mm hub-centric spacers from these folks on ebay :
https://www.ebay.com/itm/2-X-PC-HUBCENTRIC-WHEEL-SPACERS-ADAPTER-5x114-3-60-1-CB-12X1-5-3MM-TOYOTA-LEXUS/291761818596?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Hoping for a drama-free purchase and netting me enough clearance for my rear tires to not touch the fender during hard cornering.
***Oh crap, after I clicked the link again I see that they're now sold out of them!***
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Thanks for the link Prima, upon first glance it doesn't look like they offer 3mm spacers though.. it appears 5 is the lowest they go.. I'll put in a request for 3mm and see if they get back to me or not
Gville - soundslike our setups are very similar haha I was thinking that a 5mm spacer would be too close for comfort as well (although my wheels are 45 offset with a 275/30/19).. hence I wanted to look into the 3mm.. good to know that you haven't had any issues running them though!!
You can add washers to the studs and check how much thickness you need before placing the order.
Sean, rolling rear fenders will give an extra 8-10mm clearance, rolling and pulling even more.
https://www.instagram.com/ontario_fender_roll/
