Can I program an IS F key for my IS 350?
while the key fobs are visually different - the ISF key fob has the "F" logo on the back, while the 2is key fob does not, internally both key fobs are the same.
you will either have to reprogram the ISF key fob to your IS350 or pop open both key fobs and swap the internals.
Just read the RF ID on the outside. If they are the same, they should work. They have to match or they won't communicate. If you simply want the F key holder for bling and the RF (Radio Frequency) is different, grab another 350 fob matching your RF ID and put that in F body. Program and your set.
trdsw20
07-31-09 02:18 PM
