Fuel in oil. New symptoms louder ticking sound, ash on spark plugs
Old 05-29-18 | 07:38 PM
Migros's Avatar
Migros
Default Fuel in oil. New symptoms louder ticking sound, ash on spark plugs
I have an IS350 06 140k miles runs great starts right up I recently noticed fuel smell coming from oil no check engine light I'm not sure what the problem is
Old 05-29-18 | 08:41 PM
Mrfix's Avatar
Mrfix
You may have a leaking injector. Figure out which cylinder is fouled and go from there.
Old 05-30-18 | 01:03 PM
Gville350's Avatar
Gville350
Got pics of the questionable plugs?
Old 05-30-18 | 05:16 PM
Migros's Avatar
Migros
Old 05-30-18 | 05:39 PM
Migros's Avatar
Migros
All six pretty much look the same
Old 05-30-18 | 05:56 PM
Mrfix's Avatar
Mrfix
Time for a compression test?
Old 05-30-18 | 06:49 PM
Migros's Avatar
Migros
Im not driving it I parked it until i figure this out
Old 05-30-18 | 06:54 PM
Migros's Avatar
Migros
It runs great no codes i check the oil almost daily i notices this issue after a trip where car was iddling in traffic for over 2 hours and has a realy clogged air filter
Old 05-31-18 | 10:21 AM
2013FSport's Avatar
2013FSport
Plug looks pretty normal. Likely has 60,xxx + miles on it, yes?
Something to keep in mind is these are combustion engines. Short runs having multiple cold starts coupled with lots of idling can lead to a faint smell of fuel in the oil.
That said get it out on the freeway for a 50mi round trip and smell the oil when done... Bet there is no trace of it.
Taking into account even minuet traces of unburned fuel are lighter than oil and will come to the surface after sitting over night.
Way back when they used to dilute the crankcase oil with fuel so at sub zero temps it wasn't a gel. As the engine warms the fuel evaporates. You just have to sustain operating temp for a couple hours.
Old 05-31-18 | 03:17 PM
Gville350's Avatar
Gville350
According to what the internet says is the cause of an "ashy" plug is leaded fuel, fuel additives with lead, and likely a oil/fuel mixture forming deposits on the plug.
I wouldn't say that is a "normal" plug after even 100k miles for an IS350; there's definitely a problem there.
Old 05-31-18 | 06:57 PM
2013FSport's Avatar
2013FSport
Its just deposits from not being opened up and deposits in the fuel. Having pulled many plugs in life, tho not ideal, not unusual for DD that doesn't pull RPM often. We have no details about anything. OP - care to share?
Bartfriend
08-13-17 04:06 PM
Rickbean
Performance & Maintenance
11-29-14 09:45 PM
DangGS3
Maintenance
02-12-07 11:30 AM
nosbig
03-27-06 03:12 PM
Kaptnkaspy
GS - 1st Gen (1993-1997)
11-03-05 01:58 PM
