Headlight lens turning yellow
My OEM HID 2006 headlight lens are turning yellow due to UV i believe. Would it be possible to purchase an aftermarket headlight and just swap out the lens? Would any retrofitting be required?
You can fix the yellowing just by doing some research or you can take it to a specialist who can restore the headlights for you. Lots of people on youtube show how to restore them and I recommend you try that before you buy aftermarket lights.
Parrokeete (01-02-22)
Lens is not sold separately. You'll be waiting forever for someone to eventually list a cover on eBay that is most likely damaged/scratched in some way as it's typically thrown out if the rest of the headlight is unusable.
Restore the headlight, or replace the headlight. You can DIY it, or take it to a shop. AFAIK, Sams Club was doing a headlight restoration service for like $30-40 a while back where they'd sand it down and apply a UV clear coat.
sangle (06-11-18)
I do restore headlights on my own. You can buy restore kit at any stores like Walmart, autozone for like $10. It includes sand block and clearcoat wipe. Sand your headlights with sandpaper then apply clearcoat. Or you can buy sandpaper and clearcoat spray bottle separately which is cheaper way ($4 for sandpaper, $4 for clearcoat). The restore kit is one time use only while sandpaper and spray bottle can use for a lot of headlights.
ShrinkDoc (06-13-18)
I have a 05 and this worked for me. Take toothpaste (I used Crest) and rub both lenses firmly and cover with paste. Let set for approx 2-3 mins and dry then rub off with dry cloth. I had to do this twice and it worked wonders with mine and didn't cost me $$. Sounds crazy but a person at work told me about this.
The following 2 users liked this post by busynurse:
Parrokeete (01-02-22),
Like someone else mentioned, clean up the headlights by sanding them with a kit and then coat them with 2K clearcoat.... it's a 2 part UV protectant clearcoat. The can is a can within a can. You remove the lid and push it into the bottom. This causes the internal can to release a hardening agent. It's a single use can. Make sure to remove the headlights and spray somewhere that you don't mind clearcoat getting all over because it will. Should last another 7 years.
