The worlds first 3GRFSE with LMS sc kit swap
Old 07-04-18, 12:29 PM
PAVGR
PAVGR's Avatar
Originally Posted by Zynthe
Can you post the parts used for your SC setup? Did you have to do any modifications to get the SC parts to fit?
The LMS kit didn't need any modification to fit to 3GR since it's the exact same engine from outside.
Old 07-04-18, 12:42 PM
PAVGR
PAVGR's Avatar
Hey Jeff.Do you know the ignition range in both 3GR and 4GR?I m curious about the dyno result.Do you happen to know what supercharger did the Mark X using and how much boost did it run in order to reach 316BHP and 42NM of torque!I wonder what are the specs from my Procharger.If it s small and can't give the power I expected but then again in my 4GR I saw 60BHP!Why didn't I gain that in the 3GR?
Old 07-05-18, 01:55 PM
PAVGR
PAVGR's Avatar
I ve spend many hours in reading about the superchargers and I guess the Roots supercharger which Toms is using in the Mark X perhaps is more powerful at low RPMs than my Procharger.Of course I can't understand again why the 3GR makes 316BHP from 252BHP Mark X is producing and in the 2GR the same supercharger is making 360BHP from 306!
Anyway I can't understand some things and I don't want to push the car further by changing the pulley(without knowing it s safe).Mathew can't do anything else and RRracing replied that they can't help so I guess this is it.
Old 07-08-18, 07:20 PM
Jwconeil
Jwconeil's Avatar
So you can’t just buy a 350? I didn’t know that. Bummer man. Sorry your build did t go as expected. Swap in a bigger engine.
Old 07-09-18, 12:30 PM
PAVGR
PAVGR's Avatar
Thanks buddy.Actually the car is faster than it was before in all RPMs but I was expecting to reach supercharged Mark X 316BHP numbers.I can't understand why this happened.I guess it's the procharger but I can't understand why the LMS kit gave 60hp to the 4GR and just 40 to the 3GR.My buddy who did install the same engine without sc kit made 233BHP.He dynoed the IS250 190BHP and not 208 BHP as they say it is so perhaps dyno to dyno has some differences.He gained 43hp from the swap though.I just expected more.I wish someone could tell me that it s safe to raise some boost more!
Old 09-20-18, 12:00 PM
PAVGR
PAVGR's Avatar
Mathew asked me to go to an other dyno so i went to a dynopack to a Greek tuner so that he can help Mathew in tuning my car.
Old 09-20-18, 12:07 PM
PAVGR
PAVGR's Avatar
So the car made 256 hp to the wheels in just 0.4bar of boost.The Greek tuner told me that if i raise the boost to 0.6bar i could easily see 20-30hp more.
Unfortunatelly i have to see what i can do about the exhast because both Mathew and the tuner here believe that i should free the exchast as i can.
PPE headers is the best choice but i cant afford spending so much right now unfortunatelly!
Old 09-20-18, 02:04 PM
Gville350
Gville350's Avatar
There are other header options out there; you'll just have to find some company willing to ship overseas :
https://www.ebay.com/itm/OBX-Header-...item25e9c6d243
Old 09-20-18, 08:56 PM
PAVGR
PAVGR's Avatar
Thank you for the reply.Mathew also suggested to buy China headers.I emailed this company and said that my car is supercharged and told me that these headers are not made for a supercharged IS .
Old 09-21-18, 11:25 AM
Gville350
Gville350's Avatar
Just because a motor is now supercharged, doesn't mean the headers will now not work on the car. That's an odd statement on their part.
Old 09-21-18, 12:36 PM
PAVGR
PAVGR's Avatar
I know.I told them that I just want to get rid of the primary cats and free the exhaust as much as I can and they say to do it at my own risk!
Old 09-22-18, 07:29 PM
2013FSport
2013FSport's Avatar
Received 1,529 Likes on 1,272 Posts
^^ Agreed. WTH???
To bad they don't list any specs with these. ID of primary and collector. Wall thickness etc.
The china knockoffs are so cheap, you have nothing but labor to toss if it goes south!
Old 09-22-18, 08:02 PM
2013FSport
2013FSport's Avatar
Super cheap....
https://www.ebay.com/itm/FOR-06-13-L...D/401601900760
Old 09-23-18, 01:14 PM
PAVGR
PAVGR's Avatar
Originally Posted by 2013FSport
When I swapped the engine I had the primary cats removed from the OEM headers but Unfortunatelly it made a horrible metal sound when I floor it and I removed them and installed the OEM back on.I m pretty sure something didn't go so well from the guy who did this because I can't understand why this horrible noise from just removing the cats.The guy told me that there s a metal pipe inside the OEM cats and I believe this was causing the metal sound.
Old 09-24-18, 05:15 AM
PAVGR
PAVGR's Avatar
This is what i did to the OEM headers when i removed the precats and i never thought that it will make such a terrible sound
Quick Reply: The worlds first 3GRFSE with LMS sc kit swap
