Jeff can you find a PN: A760E 180°f Fill Level tube
Jeff, first off thanks for the support given and thanks in advance if you can find the A760E fill level tube for a 2IS 350.
I've seen them talked about and called both lexus and yoda, they were clueless. Maybe they don't exist?
This tube is a bit longer than stock and allows the fluid level check to be done at a temperature much closer to its normal operating temperature. Oh and 180° is ball park. It may be higher or lower.
Thanks!
Thanks!
The tube isn't a separate piece on the 2IS A760/960E/F, it's welded into the pan as far as I know... Only the plugs are available separately.
I did a bit of quick searching for the type of tube you're looking for and couldn't find much. Unless I'm missing something.
Jeff
Jeff
2013FSport (07-17-18)
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
The parts diagram doesn't have enough resolution to tell the A from the Q. Anyone? Perhaps one is the drain and one is the overflow?
2013 lexus is250/350 (gse21l-aetlha)
35-03: Transmission case & oil pan (atm)
35106 Pan sub-assy, automatic transmission oil
35106-50040
1 @ $127.15
35106A Plug sub-assy, drain (atm)
90341-10011
1 @ $3.16
35106B Gasket, drain plug (atm)
35178-30010
2 @ $2.49
35106F Bolt (for automatic transmission oil pan)
90119-06173
20 @ $0.95
35106Q Plug (for automatic transmission oil pan)
90341-10021
1 @ $3.16
35168 Gasket, automatic transmission oil pan
35168-60010
1 @ $23.72
35141B Plug (for automatic transmission case)
90341-14011
1 @ $4.86
Valve Body and oil strainer:
35330-50020 Strainer Assy, Valve Body (Filter Assy).
O-Ring for strainer 90301-31014
35106-50040
1 @ $127.15
90341-10011
1 @ $3.16
35178-30010
2 @ $2.49
90119-06173
20 @ $0.95
90341-10021
1 @ $3.16
35168-60010
1 @ $23.72
90341-14011
1 @ $4.86
