Help [staggered fitment on AWD]
I just got a set of Stance sc9 wheels (19x8.5 Front and 19x9.5 Rear +35) and i was wondering if these wheels being different widths will my Awd Is250 be alright. I've read a couple things about the transfer case turning to soup but both wheels are the same size and i don't see why that would be a problem.
You have to make sure the overall rolling diameter of the wheel doesn't change. So rim + tire has to be less than 1% of difference in rolling diameter iirc. There are some tools out there that let you test out theoretical tires on wheels so you can figure out what works. I'm sure you could search up a calculator.
https://www.fitmentindustries.com/ti...et-calculators
https://www.clublexus.com/forums/is-...thread-18.html
https://tiresize.com/calculator/
andyboy
03-14-08 10:16 PM
